It is currently Sun Jul 20, 2025 12:10 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2
PostPosted: Mon Aug 06, 2007 3:27 am
Colin,
I looked at that and the only problem that I see is that you need to detension your blade after every use. With that tensioning method you will be setting up your guides top and bottom with every use. The other method using a gauge you only have to check the guides.
PostPosted: Mon Aug 06, 2007 3:37 am
You didn't read far enough.  Count, or measure, the revolutions when you loosen the tension.  Tighten back to same spot when tightening..  They claim that if you are using their blades, the size is close enough that you don't have to run the test again until you change brands.  That's what I got out of it, anyway.
PostPosted: Mon Aug 06, 2007 4:01 am
[QUOTE=WaddyT]You didn't read far enough.[/QUOTE]
That sounds like me!!!! LOL well I think I'll give it a try and also make that jig.
Thanks Waddy
PostPosted: Mon Aug 06, 2007 5:06 am
I actually do tension by tone. I don't listen for a pitch, but for a clear tone. This indicates that you are in the middle of the blade's elastic range. Go a little looser or tighter and you will hear a loss of that resonant sound. Resawing may be an exception, though (you may need to go tighter for best results).
Tried a Griz blade a few years back. POS.
PostPosted: Mon Aug 06, 2007 5:15 am
[QUOTE=psl53]
Colin,
No just always detention the blade by the same number of turns and go back to tension by applying that number of turns, works perfectly, no need to move the guides between blade changes.
PostPosted: Mon Aug 06, 2007 8:35 am
[QUOTE=Howard Klepper]
Tried a Griz blade a few years back. POS.[/QUOTE]
LOL
PostPosted: Wed Aug 08, 2007 1:49 pm
Dean, or anyone who is familiar with the Starett Blades Dean had mentioned. Where can I buy these blades?
Dean mentioned-"Equal to the Lenox carbide in quality is the Starrett, and less expensive. First time I've ever said that about Starrett. They have a 3/4" with a .035 kerf!"
Peace,Rich
PostPosted: Fri Aug 10, 2007 12:45 am
     I always keep sanding belts and saw blades seperate for metal. For metal you should use a much higher TPI.
     Not that I cut metal that much!
PostPosted: Fri Aug 10, 2007 1:04 am
The Manufacturer of the Timber Wolf blade contends that cutting Lexan is what probably did in my saw blade and that I should have used a bimetal blade.  I cut Lexan with my Grizzlys with no ill effect that I can tell.  Bummer!
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Fri Aug 10, 2007 1:23 am
I'd like to know if anyone has used the Starrett blades and what model, the website has quite a few. Also I tried a few distributors in Colorado and they didn't have a clue about bandsaw or blades so if someone has dealt with someone "in the know" please post it here.
thanks
Peter
PostPosted: Fri Aug 10, 2007 1:36 am
So far, I have tried:
Sears blade - 3/8" - 6tpi  - cut fine though rough - narrow kerf  .83mm
$14.99 mail order through Sears.
Timberwolf - 1/4" - 10tpi - seems very rough for a 10 tooth blade - lots of shredding on bottom of cut pieces.  Thin kerf  .86mm or so - price 14.95 - 70 1/4" blade.
Lennox custom welded - 1/4" - 6tpi - nice smooth cut - bigger kerf at 1.2mm roughly.  Same result with the 3/8 6 tooth blade.  Price of the lennox blades - between $8.00 - $9.00 for a 70 1/2" blade @ 6tpi.  Right now Lennox is at the top of my list.  I am going to order a couple of their narrow kerf blades for fine cutting (i.e. rosettes etc.).
PostPosted: Fri Aug 10, 2007 2:22 am
  Lenox not Lennox.
PostPosted: Mon Aug 13, 2007 10:47 am
[QUOTE=Dean]Equal to the Lenox carbide in quality is the Starrett, and less expensive. First time I've ever said that about Starrett. They have a 3/4" with a .035 kerf!
Dean
Dean, where are you getting these. I priced a Lenox 1" woodmaster for $110 (144") The price I got for a 3/4" starrett was $295 and for a 1/2" $280. If you or anyone else has a better source please post it, I love to get a carbide for under $100.
Peter
Users browsing this forum: Bing [Bot] and 7 guests
